Автор Тема: Как запрограммировать брелок  (Прочитано 124372 раз)
Оффлайн Еlеmеntчик
  • Москау сити. (Коньково)
« : 04 Февраля 2008, 10:39:31 »
Honda Element 03-04 Keyless Remote Programming Instructions  :bu:
Please follow the instructions step-by-step in order for the remote programming to work. These instructions are useful for 2003 2004 Honda Element. This procedure clears the transmitter codes and creates new ones, so you must program all remotes at the same time, even if one or more is already working.
Enter the car and close all doors.
Each of the following steps must be completed within five seconds of completing the previous step. If you take longer or make a mistake, start the entire procedure over again.
Insert the key into the ignition, and hold one remote in your left hand. Whenever the instructions say to press the LOCK button, you should press the lock button on the remote for about a second and then release it.
Perform each of the following three steps in order, then repeat all three steps two more times, for a total of three times each:
           1. Turn the ignition switch to the ON position, marked II.
           2. Press the LOCK button.
           3. Turn the ignition switch to the Off  position, marked I.
Do this three times!
Next, turn the ignition switch to the ON position (II) for a fourth time.
Press the LOCK button again. The door locks should now make a cycling sound, indicating that the system has entered Programming Mode.
Press the LOCK button one more time to program this remote. If you have other remotes to program, press the LOCK button on each one in turn. The door locks should make the cycling sound after you press LOCK on each remote. You may program up to three remotes, and they must all be programmed within ten seconds of each other.
Turn the ignition off and remove the key. The remotes are now programmed and may be tested.
If you've got a trunk/hatch release, hold the button for this function for a few seconds.
« Последнее редактирование: 06 Июля 2008, 22:45:57 от Romel' »
Так просто.
Оффлайн ZV4
  • Дачник
  • Москва, Лужники
Вопрос тупой, но все же...
LOCK BUTTON - это кнопка на брелке (на новом или на старом???) или на водительской двери?
Увы. Продал
Программировал много раз. Смысл в 2-х словах:
нужно проделать 3-и раза одну процедуру (двери должны быть закрыты, а замки открыты):
1. выключить зажигание
2. включить зажигание
3. нажать на брелке "Замочек"
4. выключить зажигание
_________ _________ _________ ___
на 4-й раз
1. включить зажигание
2. нажать на брелке "замочек"
при этом центральный замок немного отщелкнет
3. повторно нажать на брелке "замочек", а если 2-а брелка, то на втором тоже нажать на "замочек" (если не нажать на втором, то второй уже не будет работать)
ВСЕ - брелки запрограммированы!!!
Оффлайн vvs962
А вот говорят  что 2 ключ может быть в машине?То где?У меня кстати  не запрограмировался  брелок
Оффлайн FX-40-DELTA
Купил машину .но брилков не было.Их можно где то докупить и запрограммировать ?
а может стоит сигналку поставить+секретку? Элики в последниее время пользуются небольшим спросом у угоньщиков
Родные брелки это простые открывашки  - без каких-либо охранных функций.
Но если решите остановиться на родной системе обращайтесь
Оффлайн FX-40-DELTA
Спасибо.обращусь!
Оффлайн DENZZE
    • БЕЛЛАРАША
У меня тоже брелок почемуто не настраевается,может в 2003г в базовой комплектации их небыло?И с ключа открывается только водительская дверь,пассажиру надо откр. централкой,закрывается нормально.Или так и надо?
Оффлайн FX-40-DELTA
я поставил сигналку с пейджером.обошлось все в 6000р и теперь радуюсь жизни.все открывается и закрывается и не надо пароноиЦЦа закрыл ты машину или нет.достаточно взглянуть на брелок))и если шо запиликает
Оффлайн FX-40-DELTA
звиняйте что не в тему.вырвалось
Родной брелок не работает? Может просто батарейка?
Так и надо.
С брелка тоже самое. Нажал "открыть" - только водительская, еще раз - все остальные.
Оффлайн DENZZE
    • БЕЛЛАРАША
Re: Как запрограммировать брелок
« Ответ #11 : 31 Мая 2011, 22:47:09 »
Если ключ в дверях поворачиваеш два раза,должно все открыватся или только водительская? У меня только водительская.Батаре йку пробовал переставлять,правда из б/у брелка
« Ответ #12 : 01 Июня 2011, 08:06:04 »
Ключ открывает ту, в дырку которой пихаешь и только её. :)
На брелке лампочка то хоть моргает?
Оффлайн patrick
    • MinsK
« Ответ #13 : 01 Июня 2011, 19:51:41 »
машинка приехала только с ключом.
заказал на ebay вот такой. вроде подходит к Эльке.
его тоже таким же образом пришить к машине можно?
Привет.
А сколько это будет стоить
« Ответ #15 : 01 Июня 2011, 23:55:12 »
Привет.
Обратись в раздел Bibikamarket.ru  там и по ценам и по сигналке определишся
« Ответ #16 : 02 Июня 2011, 11:14:40 »
Инструкция же выше висит
Кстати, а блок дистанционного открывания установлен?
Бывает, что нет.
Оффлайн patrick
    • MinsK
« Ответ #17 : 02 Июня 2011, 11:26:20 »
Бывает, что нет.
а пес его знает. комплектация вроде не плохая. ключик придет посмотрим.
я просто уточнить хотел подойдет ли вышеописанная инструкция к такогорода болванке?
не подойдет - поставлю сигналку с автопуском
Оффлайн spr
    • SPb
« Ответ #18 : 24 Июля 2011, 14:31:46 »
Подскажите по проблемке - после снятия клемм с аккума непонятно работает центральный замок - и ключ и брелок открывают машину, но как только закхлопнешь дверь -самостоятельно  срабатывает ЦЗ и закрывает все двери. Нужно что-то  штатное запрограммировать в эле или  искать инструкцию к нештатной сигналке?
Оффлайн Диман
« Ответ #19 : 06 Августа 2011, 19:20:30 »
Это у тебя нештатная сигналка разберайся с ней
